Script for hotkey for Incremental Transformation
The-Digital-Shaman
Message 1 of 1
The-Digital-Shaman
Hi There,
To avoid opening transformation/rotation/scale settings window each time I want to change value of snap incremental move/rotate/scale, I have made a shelf buttons with options under right click.
However, the script doesn't work until I will manually open the settings at least once.
It needs some improvements.
Here are the scripts:
print("50 Units Move Step Set");
manipMoveContext -e -snapValue 50 $currManipMovePropertiesCtx;
print("45 Degrees Step Set");
manipRotateContext -e -snapValue 45 $currManipRotatePropertiesCtx;
print("25 Percent Scale Step Set");
manipScaleContext -e -snapValue 25 $currManipScalePropertiesCtx;
$currManipScalePropertiesCtx;  causes issues...
Thanks for any help,
DS
Replies (0)
