Announcements
Query selected connections in the node editor with python
I was wondering if there is a way to query the selected connections in the node editor via python ?
The connection which are yellow I would like to get.
Cheers
Marcell
mspeer
Hi!
It should be possible to get the connected nodes based on connected Attribute(s), but not on the color used for connection display.
batarg
any luck with querying selected connection? im trying to make simple tool for focusing on two nodes on both ends.
i think it should be under the hood of qt... but can't figure out where start to dig
batarg
oh god) that was not exactly what i searched but my main goal was achieved
select connections in node editor and run[mel]:
string $ned = `getCurrentNodeEditor`;
nodeEditor -e -selectConnectionNodes $ned;
// with pinning and clearing
//nodeEditor -e -pinSelectedNodes 1 $ned;
//NodeEditorGraphClearGraph;
// just clearing and adding
nodeEditor -e -frameSelected -addNode "" $ned;
batarg
wow.... found even simplier »out of the box« method (same, just select connection(s)) [mel]:
nodeEditor -e -graphSelectedConnections `getCurrentNodeEditor`;
