Python Script for Querying Joints in a Scene
johngrivas582
Observer Observer
johngrivas582
Observer
Observer
I’m trying to create a loop that will cycle through a scene query for joints and create a locator on each joint, using python, any Ideas ?
Hello @johngrivas582 ,
Hope you're doing fine.
This is a very old script I had written.
It does what you've requested, give it a try on your scene file. Let me know if it works for you and yes tweak it for your convenience.
import maya.cmds as mc
import codecs
#jnt_selection
sel = mc.ls(sl = True)
jnt_hie_lst = []
#print(sel)
#for_loop_for_appending_jnt_hie_in_lst_and_creating_controllers
for s in sel:
    jnt_hie = mc.select(s, hi = True)
    jnt_hie_sel = mc.ls(sl = True)
    print (jnt_hie_sel)
    jnt_hie_lst.append(jnt_hie_sel)
    for j in jnt_hie_sel:
        new_name = codecs.encode(j)
        new_crc = mc.spaceLocator(name = '%s_ctrl' %new_name)
        new_grp = mc.group(name = '%s_ctrl_grp' %new_name)
        new_par = mc.parentConstraint(j, new_grp)
        mc.delete(cn = True)
        app = mc.parentConstraint(new_crc, j)
#print(jnt_hie_lst)
#preserve_ctrls_lst
ctrls_lst = []
#for_loop_for_querying_the_jnt_and_and_appending_the_query_in_the_ctrls_lst
for j in jnt_hie_lst:
    jnt_qry = mc.select(j)
    jnt_qry_sel = mc.ls(sl = True)
    for j_qry in jnt_qry_sel:
        mc.select(j_qry)
        mc.ls(sl = True)
        jnt_par_qry = mc.parentConstraint(tl = True, query = True)
        print(jnt_par_qry)
        jnt_par_qry_pop = jnt_par_qry.pop()
        ctrls_lst.append(jnt_par_qry_pop)
#print(ctrls_lst)
Kahylan
Hi!
So the code posted way quite flawed.
1) it needs selection to be actve
2) It does preserve some controls you never talked about...
The script you need is very simple:
joints = mc.ls(type= "joint")
for j in joints:
    loc = mc.spaceLocator(n= "{0}_LOC".format(j))
    mat = mc.xform(j, m= True, ws= True, q= True)
    mc.xform(loc, m = mat, ws = True)
It's a python script so you'll need to run it from a python tab.
I hope it helps!
