Python API 2.0 MPlug attributes
I am trying to use the Python API 2.0 and MPlug in particular.  I can't find a way to lock the attribute.  There is a "isLocked" which gives a boolean result.  But how do you set the locked state?  The API 2.0 discussion says that the attributes should be available to be set directly.  But there is an error when trying MPlug.locked = True.  What am I missing?
vijaya.prakash
In C++, you can use MPlug.setLocked(True) but in Python, you should use MPlug.setAttribute() with "lock" parameter.
Vijaya Prakash.
vijaya.prakash
Use the below python code to set the lock attribute, there is no specific API in Python 2.0 API in OpenMaya.
import maya.cmds as cmds
cmds.sphere( n="sphere" )
cmds.setAttr( 'sphere.translateX', 5 )
cmds.setAttr( 'sphere.translateX', lock=True )
Vijaya Prakash.
You are incorrect in your information.  API 2.0 does provide this functionality.  I assumed "isLocked" was read only.  It actually can be set as well.
MPlug.isLocked = True
vijaya.prakash
Yes, You are correct. there is no "setLocked()" API in OpenMaya Python 2.0. Instead we have to use "isLocked()" method for both setting the lock as well as checking the lock. Below is the actual documentation of isLocked() method.  It has both Read and Write access.
OpenMaya.MPlug.isLocked
static
 True if plug is locked against changes.
Type: bool
Access: RW
Description: True if plug is locked against changes.
Vijaya Prakash.
