I am working in Pyside. Every time I re-open the window it pops back to the middle of the screen. How can I get either Maya or Windows to remember the position and size?
Here is some basic code I am working with:
import traceback
from PySide import QtCore
from PySide import QtGui
from shiboken import wrapInstance
import maya.cmds as cmds
import maya.OpenMayaUI as omui
import pymel.core as pm
def maya_main_window():
Return the Maya main window widget as a Python object
main_window_ptr = omui.MQtUtil.mainWindow()
return wrapInstance(long(main_window_ptr), QtGui.QWidget)
class TestTool(QtGui.QDialog):
def __init__(self, parent=maya_main_window()):
super(TestTool, self).__init__(parent)
self.qtSignal = QtCore.Signal()
def create(self):
Set up the UI prior to display
self.setWindowTitle("Test")
self.setWindowFlags(QtCore.Qt.Tool)
#self.resize(400, 250) # re-size the window
self.setGeometry(650, 200, 600, 300)
self.setFixedHeight(580)
self.setFixedWidth(300)
QtGui.QToolTip.setFont(QtGui.QFont('SansSerif', 10))
if __name__ == "__main__":
try:
ui.deleteLater()
except:
pass
ui = TestTool()
try:
ui.create()
ui.show()
except:
ui.deleteLater()
traceback.print_exc()
