Preserve edges python command
Hello world, this is my first post in the forum, I hope can you help me with a simple thing in Maya but  always drive me crazy, when I have some meshes in the scene who I can to make a switch to activate the "UV Boundary Smoothing --->Preserve Edges" I was try some time and nothing happened, thank you for some help and your time.
The idea is when I aplicate the smooth mesh preview the borders of the meshes adjusting perfect in the same time with the borders of the uvs with a script
I try to find the command in the python area and pummel and I can't find the solution, I was try to osdFvarBoundary command and nothing happened, that option don't have the preserver edges flag.
if somebody have some idea I will appreciate a lot of
cheers.
45b3f1ed-d93d-473f-b395-3865673bdccb,640,590
jmreinhart
setAttr "pCubeShape1.osdFvarBoundary" 2;
is this what you're looking for?
Hi dude, thank you for reply, I appreciate the time to have to help me,  in relation to the answer the code apply to specific object with an Attribute, I need apply the code to deferents objects with a variable to accelerate the modeling process, I hope fin a solution, I have problems with that time ago, I try to share my screencast to show you, and again thank you for your help.
https://autode.sk/3j0svLE
jmreinhart
source_obj = ''
target_obj = ''
cmds.setAttr(target_obj + '.osdFvarBoundary', cmds.getAttr(source_obj + '.osdFvarBoundary'))
something like this will work
hi dude, thank yo for your help, I can found a portal Solution,  your code help a lot of to make it working, I write some variables additional with selected objcts
sourceObj = mylist.pop(0)
targetObj = mylist.pop(1)
