Please correct my mel to python command (Show & Hide NURBS Curves in MAYA Hotkey in python).
amaterasu-qbb
Message 1 of 10
amaterasu-qbb
I am rewriting the mel command on this site to a python command for learning python.(maya2019)
https://www.patrickgambleanimation.com/post/show-hide-nurbs-curves-in-maya-hotkey
code[mel]:
string $activePanel = `getPanel -wf`;
if (`modelEditor -q -nurbsCurves $activePanel` == 1) {
   modelEditor -e -nurbsCurves 0 $activePanel;
} else {
   modelEditor -e -nurbsCurves 1 $activePanel;
 my code[python]
import maya.cmds as cmds
activePanel = cmds.getPanel(withFocus=True)
if cmds.modelEditor(query=True, nurbsCurves=True,  activePanel=True):
    cmds.modelEditor(edit=True, nurbsCurves=False, activePanel)
else:
    cmds.modelEditor(edit=True, nurbsCurves=True, activePanel)
 If I search for Technical Document in the linked command, I can find
  • getPanel<undoable, NOT queryable, NOT editable.>(-wf= withFocus boolean)
  • modelEditor<undoable, queryable, and editable.>[-nc= nurbsCurves boolean]
I can not find string $activePanel so this could be a variable.
I am a beginner in programming. learning on Zurbrick's site.
http://zurbrigg.com/tutorials/beginning-python-for-maya/2-1-maya-commands
It's not finished yet. Please give me various advice.
Replies (9)
Message 2 of 10
mspeer
Hi!
Place "activePanel" at the beginning.
if cmds.modelEditor(activePanel, query=True, nurbsCurves=True):
    cmds.modelEditor(activePanel, edit=True, nurbsCurves=False)
else:
    cmds.modelEditor(activePanel, edit=True, nurbsCurves=True)
Message 3 of 10
amaterasu-qbb
Hi! @mspeer thanks for the reply.
I got this error.
# Error: line 1: TypeError: file <maya console> line 5: Invalid flag 'activePanel'
am I doing wrong in a variable?
Message 4 of 10
stuzzz
hi,
else:
    cmds.modelEditor(activePnale, edit=True, nurbsCurves=True)
Message 5 of 10
stuzzz
oupss too late
Message 6 of 10
mspeer
Hi!
@amaterasu-qbb
It seems you still use "activePanel=True".
This is a variable and you can't use this with a flag, so simply use "activePanel" as shown in the examples provided by @stuzzz  and me.
For further help, please provide your code which produces the error.
Message 7 of 10
amaterasu-qbb
Hi! I was moving sorry for the reply.
thank you, everyone. I made it!
# Show hide curves in python
else:
    cmds.modelEditor(activePanel, query=True, edit=True, nurbsCurves=True)
thank you for helping me!
Message 8 of 10
mspeer
Hi!
Although this works, the last line is still wrong.
It should be:
else:
You don't want to query something, you want to set something.
Message 9 of 10
amaterasu-qbb
Thanks. I didn't need to query it because I already queried it with if cmds.modelEditor(activePanel, query=True, nurbsCurves=True): as you said.
And it worked.
Message 10 of 10
deepakamba13
please can you make Tweak/Marquee keyboard hotkey
