Update on another attempt:
Rendering with hardwareRenderer 2.0 and enable the UI checkbox y objectTypeFilter makes the hud renderable with this engine in maya GUI mode. So maybe rendering with hardware renderer some custom jpgs and then packing up all the files into a mp4 with ffmpeg would do the trick as well.
Tried configuring hardware renderer and it doesnt work either..........
Those are the steps i follow:
import maya.standalone
maya.standalone.initialize()
import maya.mel
maya.mel.eval('OnUICallback 9;')
maya.mel.eval('objectTypeFilterAllCallback;')
import maya.cmds as mc
mc.hwRender('mycamera')
I also tried this:
import maya.mel
mc.playblast(format='avi', percent=100, quality=100, compression='none', viewer=True, forceOverwrite=True, widthHeight=[1920,1080], sound=None, filename='mycurrentscenemovie.avi')
But with this last try, i get a maya crash as follows:
Initialized VP2.0 renderer {
Version : 2016.11.35.12. Feature Level 4.
Adapter : Quadro K4000/PCIe/SSE2
Vendor ID: 4318. Device ID : 4602
Driver : .
API : OpenGL V.4.5.
Max texture size : 16384 * 16384.
Max tex coords : 8
Shader versions supported (Vertex: 4, Geometry: 4, Pixel 4).
Shader compiler profile : (Best card profile)
Active stereo support available : 0
GPU Memory Limit : 3072 MB.
CPU Memory Limit: 23338.8 MB.
MultiDraw consolidation attempted to enable, but the graphics device does not support it. MultiDraw will be disabled.
OpenCL evaluator is attempting to initialize OpenCL.
Detected 1 OpenCL Platforms:
0: NVIDIA Corporation. NVIDIA CUDA. OpenCL 1.2 CUDA 7.5.9.
Supported extensions: cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d9_sharing cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts
OpenCL evaluator choosing OpenCL platform NVIDIA Corporation.
OpenCL evaluator is unable to find a GPU device that can share VBOs with OpenGL.
Stack trace:
3dGraphics.dll!T3dPort::getColorTable
3dGraphics.dll!T3dPort::getModelViewColorTable
3dGraphics.dll!T3dPort::setModelViewColorTable
3dGraphics.dll!T3dPort::ColorTableGuard::~ColorTableGuard
OGSMayaBridge.dll!OGSMayaBaseRenderer::updateUIElements
OGSMayaBridge.dll!Ttask::initTbb
OGSMayaBridge.dll!OGSApplicationBridge::UpdateScene
OGSMayaBridge.dll!OGSMayaRenderer::updateScene
OGSMayaBridge.dll!OGSMayaBaseRenderer::performSceneRender
OGSMayaBridge.dll!TplayblastOGSBridge::grabPixels
AnimUISlice.dll!TanimationEditorCmd::setAnimEditor
CommandEngine.dll!TmetaCommand::doCommand
CommandEngine.dll!TpythonInterpreter::dispatchMayaCommand
python27.dll!PyCFunction_Call
python27.dll!PyEval_GetFuncDesc
python27.dll!PyEval_EvalFrameEx
python27.dll!PyEval_EvalCodeEx
python27.dll!PyRun_FileExFlags
python27.dll!PyRun_InteractiveOneFlags
python27.dll!PyRun_InteractiveLoopFlags
python27.dll!PyRun_AnyFileExFlags
python27.dll!Py_Main
KERNEL32.DLL!BaseThreadInitThunk
ntdll.dll!RtlUserThreadStart
