No module named xlsxwriter
Hello All,
I am on location using a loaner laptop with Maya 2019 installed to do some work. However, when I attempt to use one my scripts, I get an error that says there was an error because no module named xlsxwriter was found. I've checked to make sure that Python27 is installed and I ran a pip install to add xlsxwriter. I checked it using Geany to make sure that I could create an xlsx file with a simple 'Hello world' script. I am able to produce the xlsx file using Geany, so I'm not sure why it won't work in Maya. Any suggestions?
Below is a screenshot of the simple test I'm running in Maya until I can get it figured out. Any help would be appreciated.
morel.katia
Community Visitor
Community Visitor
did you get any info since back then ?
I got the same issue as you...
Hope you found a solution
K.
cheng_xi_li
Autodesk Support
Autodesk Support
If you are using Python 2(e.g. Maya 2020, Maya 2019...). You'll need to install it manually.
You can download it from here.
https://pypi.org/project/XlsxWriter/2.0.0/#files
Use mayapy setup.py install to install it. You may need administrator or root privilege to install it if your Maya is installed by default locations.
Yours,
Li
