Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
MUIDrawManager displays font size 12 differently when called from drawFeedback and doDrag
0 REPLIES 0
Message 1 of 1
jmreinhart
290 Views, 0 Replies
So I have a plugin that draws a weight value for each selected vertex. When I am modifying that weight value by clicking and dragging the text is drawn at the correct size. When the mouse is not held down the same weight value is drawn by the drawFeedback method and it is smaller. Very strangely this only appears to occur when the fontSize is 12. If the fontSize is 11 or 13 the size of the text is consistent.
I attached two short videos that show off the issue, the first is me testing the full tool, and in the second I draw the text in a static position to show it more easily.
This affects both the text and text2d function.
I am encountering this issue in Maya 2023 on Windows with a plugin compiled using Visual Studio 2017.
0 REPLIES 0
Technology Administrators
