So I tried to rotate and image in the UV editor for a class project and cannot for the life of me find out how I turned the tools off.
Hi!
Try a reset of your preferences.
Rename the folder prefs in folder 2017 to something like prefs_backup, or to reset everything, the folder 2017 to 2017_backup. Maya creates new folders. Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
(The "light" solution: Windows -> Settings/Preferences -> Preferences -> Edit -> Restore Default Settings)
What?!? I've been using Maya for years, and I never new about this "light" version of resetting preferences. I've been doing the move-the-prefs-folder thing this whole time. Thanks. 🙂
Hi!
"To return to the default factory settings (reset), choose Edit > Restore Default Settings in this window. Note that this resets the preferences in every category in the Preferences window."
http://help.autodesk.com/view/MAYAUL/2017/ENU/?guid=GUID-A62CF59A-3600-4709-A3B7-0F2DB83EC829
This "light" reset does not include all settings in Maya, so sometimes you still have to choose the folder-procedure to make sure everything is reset.
