(MEL)writing a renamer script.
absoluteKelvin
absoluteKelvin
im currently stuck on a supposedly straightforward section of my script. Im writing a script that is striping the Suffix of the naming. To do that im using tokenize to separate and store the strings after "_". But im stump on the why it doesnt print the result.
    string $userSel[]=`ls -sl -transforms`;
    string $buffer[];
    int $token;
    for ($node in $userSel){
        $token = `tokenize $node "_" $buffer`;
        print $buffer[$token];
https://www.artstation.com/kelvintam
trs_andre
Hi!
The result of the tokenize command is the number of tokens in which the string is split, so if you tokenize "hello_world" with the "_" character, the result will be 2.
So, in this case, buffer will only be populated in the position 0 and 1, so printing buffer[2] will return nothing.
Might this be your case?
André Moreira
Game Developer / Technical Artist
LinkedIn
rajasekaransurjen
Hi, Try This...
    string $buffer[];
    int $token;
        print $buffer[($token-1)];
absoluteKelvin
it works perfect! thanks
