Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Mel Script Not Working on MAYA 2018
ebarrettK5ZLP
ebarrettK5ZLP
Hey,
How is it going, I have this Mel script but for some reason it works on Maya 2022 but it has errors on Maya 2018. Would any one be able to point out why it my not be working. Thank you
//Returns TimeWarp State as Enabled/Disabled
global proc string checkTimeWarpState ()
global int $timeWarpState;
string $state;
$timeWarpState = `getAttr time1.enableTimewarp`;
if ($timeWarpState == 0)
$state = "Disabled";
//print("checkTimeWarpState: " + $state + "\n");
else if ($timeWarpState == 1)
$state = "Enabled";
//print("State: " + $state + "\n");
return $state;
} // TimeWarp State return end
global proc Enable_TimeWarp_HUD ()
//Enable timeWarp
EnableTimeWarp;
//set TimeWarp State to var to read later
print("timeWarpState: " + $timeWarpState + "\n");
print("checkTimeWarpState: " + checkTimeWarpState() + "\n");
if ($timeWarpState == 1){
//Turn on heads headsUpDisplay
headsUpDisplay -section 3
-block 0
-blockSize "large"
-label "TimeWarp :"
-labelFontSize "large"
-command "checkTimeWarpState()"
-event "SelectionChanged"
-nodeChanges "attributeChange"
HUDTimeWarpEnabled;
}else if ($timeWarpState == 0){
//setTimeWarp();
headsUpDisplay -rem HUDTimeWarpEnabled;
}//check enabled/disabled end
}//EnableHUD end
Kahylan
Hi!
The problem comes from the fact that the toggle Command "EnableTimeWarp" that automatically switches timewarp state didn't exist yet in Maya 2018. If you use an if/else setAttr Toggle to do the same it should work:
string $state;
$state = "Enabled";
return $state;
//Enable timeWarp
    setAttr "time1.enableTimewarp" 0;
else {
    setAttr "time1.enableTimewarp" 1;
-block 0
-blockSize "large"
-label "TimeWarp :"
HUDTimeWarpEnabled;
//setTimeWarp();
}//EnableHUD end
Enable_TimeWarp_HUD ();
I hope this helps!
ebarrettK5ZLP
Thank you so much @Kahylan , That worked perfectly
