Maya2017 can`t use the UV Editor
Hello
My Maya 2017 and 2018 both can`t use the UV Editor
Maya 2017 has been upgraded to update 4 the UV Editor still not work
The script is as follows:
// Error: file: C:/Program Files/Autodesk/Maya2017/scripts/others/uvTkBuildUVSetsOptions.mel line 77: Cannot find procedure "textureWindowToggleAutoLoadTextures". //
// Error: file: C:/Program Files/Autodesk/Maya2017/scripts/startup/uiRes.mel line 107: displayString identifier "m_texturePanel.kPolygons" does not exist. //
Maya 2018 have the same problem
Please help solve this problem,it's bothering me for a long time
Ding Chao
mspeer
Hi!
Try a reset of your preferences.
Rename the folder prefs in folder 2018 to something like prefs_backup, or to reset everything, the folder 2018 to 2018_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
Hi,mspeer
Thank you for your reply~!
I used this method to try to repair, but did not work
