Hey guys,
first time poster. Would be great if you could help me out here 🙂
I am writing some python code at the moment that includes a custom node. In my test-suit (using lettuce) I am initializing maya-standalone and try to load the plugin for the node. Doing that from an external interpreter crashes maya. The crash happens every time and always when I do cmds.loadPlugin('insertPluginNameHere.py'). It works fine when doing it in the GUI-version and it also works in mayapy.exe. I compared os.environ in my external interpreter with the one in mayapy and all the paths should be fine (initializing and importing cmds does work). Is there anything else I can check to make sure that I have set up the environment correctly? I am on Windows7 64 bit.
I also attached WinDBG to the python process and catched the error but it doesn't really help me,- maybe it makes sense to one of you. Including it here just for reference. Was hoping it might give me a hint on what to do differently when setting up the environment...
http://pastebin.com/ybV3RtH0
I used lettuce-driven tests for custom nodes successfully in the past with Maya2012 and I am not sure what has changed or what I am doing inccorrectly. Any idea is very appreciated. Thanks guys,
Matti.
I realize this is an old thread, but:
I have noticed a lot of plugins crash with Maya 2012 standalone, but load fine in Maya 2014 standalone. Same plugin, just compiled for different versions of Maya.
