Maya Crash: Python save file after baking
Hi all,
My Maya is crashing whenever I run the pymel.core.newFile() after running the bakeResults command. I've tried using different flags and baking one node at a time. Attached is the error that I get when running the code
cheng_xi_li
Autodesk Support
Autodesk Support
I am not sure if it is related to pymel, but for Python/C++/.net APIs. If there were unsaved changes in the scene, you must specify force flag when creating a new scene. Otherwise, the function will fail and return an unknown error.
Yours,
Li
Ahh yes, I figured it out. I had to select the nodes and then bake instead.
