Maya can not find the plug-in path
mopmopmop
Observer Observer
mopmopmop
Observer
Observer
I installed maya 2018 on a new pc windows 10, but it does not save or open any files. When I went to see the plug-in manager there was no plug-in enabled.
- I already reinstalled the program
- I already deleted all directories
- already tried open it by external HD
- has already resented NVIDIA plug-in
My Output say:
Could not find maya.utils._guiExceptHook.
Invalid Python Environment: Python is unable to find Maya's Python modules
Python Environment:
  PYTHONHOME = C:\Users\Mingalll\AppData\Local\Programs\Python\Python36
  PYTHONPATH = C:\Users\Mingalll\AppData\Local\Programs\Python\Python36\Lib;C:\Users\Mingalll\AppData\Local\Programs\Python\Python36\DLLs;C:\Users\Mingalll\AppData\Local\Programs\Python\Python36\Lib\site-packages;C:/Program Files/Autodesk02/Maya2018/plug-ins/ATF/scripts;C:/Program Files/Autodesk/Bifrost/Maya2018/scripts/boss;C:/Program Files/Autodesk/Bifrost/Maya2018/scripts/presets;C:/Program Files/Autodesk/Bifrost/Maya2018/scripts;C:/Program Files/Autodesk02/Maya2018/plug-ins/MASH/scripts/apiclient;C:/Program Files/Autodesk02/Maya2018/plug-ins/MASH/scripts/flux;C:/Program Files/Autodesk02/Maya2018/plug-ins/MASH/scripts/googleapiclient;C:/Program Files/Autodesk02/Maya2018/plug-ins/MASH/scripts/httplib2;C:/Program Files/Autodesk02/Maya2018/plug-ins/MASH/scripts/MASH;C:/Program Files/Autodesk02/Maya2018/plug-ins/MASH/scripts/MASHAET;C:/Program Files/Autodesk02/Maya2018/plug-ins/MASH/scripts/MayaToAE;C:/Program Files/Autodesk02/Maya2018/plug-ins/MASH/scripts/oauth2client;C:/Program Files/Autodesk02/Maya2018/plug-ins/MASH/scripts/uritemplate;C:/Program Files/Autodesk02/Maya2018/plug-ins/MASH/scripts/flux/ae;C:/Program Files/Autodesk02/Maya2018/plug-ins/MASH/scripts/flux/resources;C:/Program Files/Autodesk02/Maya2018/plug-ins/MASH/scripts/flux/ui;C:/Program Files/Autodesk02/Maya2018/plug-ins/MASH/scripts/flux/resources/icons;C:/Program Files/Autodesk02/Maya2018/plug-ins/MASH/scripts;C:/Program Files/Autodesk02/Maya2018/plug-ins/fbx/scripts;C:/Program Files/Autodesk02/Maya2018/plug-ins/camd/scripts;C:/solidangle/mtoadeploy/2018/scripts;C:/Program Files/Autodesk02/Maya2018/plug-ins/camd/scripts;C:/Program Files/Autodesk02/Maya2018/plug-ins/camd/scripts;C:/Program Files/Autodesk02/Maya2018/plug-ins/substance/scripts;C:/Program Files/Autodesk02/Maya2018/plug-ins/xgen/scripts/cafm;C:/Program Files/Autodesk02/Maya2018/plug-ins/xgen/scripts/xgenm;C:/Program Files/Autodesk02/Maya2018/plug-ins/xgen/scripts/xgenm/ui;C:/Program Files/Autodesk02/Maya2018/plug-ins/xgen/scripts/xgenm/xmaya;C:/Program Files/Autodesk02/Maya2018/plug-ins/xgen/scripts/xgenm/ui/ae;C:/Program Files/Autodesk02/Maya2018/plug-ins/xgen/scripts/xgenm/ui/brushes;C:/Program Files/Autodesk02/Maya2018/plug-ins/xgen/scripts/xgenm/ui/dialogs;C:/Program Files/Autodesk02/Maya2018/plug-ins/xgen/scripts/xgenm/ui/fxmodules;C:/Program Files/Autodesk02/Maya2018/plug-ins/xgen/scripts/xgenm/ui/tabs;C:/Program Files/Autodesk02/Maya2018/plug-ins/xgen/scripts/xgenm/ui/util;C:/Program Files/Autodesk02/Maya2018/plug-ins/xgen/scripts/xgenm/ui/widgets;C:/Program Files/Autodesk02/Maya2018/plug-ins/xgen/scripts
  System modules located at: C:\Program Files\Autodesk02\Maya2018\bin\python27.zip
  Search path (sys.path):
    C:\Program Files\Autodesk02\Maya2018\plug-ins\ATF\scripts
    C:\Program Files\Autodesk\Bifrost\Maya2018\scripts\boss
    C:\Program Files\Autodesk\Bifrost\Maya2018\scripts\presets
    C:\Program Files\Autodesk02\Maya2018\plug-ins\MASH\scripts\apiclient
    C:\Program Files\Autodesk02\Maya2018\plug-ins\MASH\scripts\flux
    C:\Program Files\Autodesk02\Maya2018\plug-ins\MASH\scripts\googleapiclient
    C:\Program Files\Autodesk02\Maya2018\plug-ins\MASH\scripts\httplib2
    C:\Program Files\Autodesk02\Maya2018\plug-ins\MASH\scripts\MASH
    C:\Program Files\Autodesk02\Maya2018\plug-ins\MASH\scripts\MASHAET
    C:\Program Files\Autodesk02\Maya2018\plug-ins\MASH\scripts\MayaToAE
    C:\Program Files\Autodesk02\Maya2018\plug-ins\MASH\scripts\oauth2client
    C:\Program Files\Autodesk02\Maya2018\plug-ins\MASH\scripts\uritemplate
    C:\Program Files\Autodesk02\Maya2018\plug-ins\MASH\scripts\flux\ae
    C:\Program Files\Autodesk02\Maya2018\plug-ins\MASH\scripts\flux\resources
    C:\Program Files\Autodesk02\Maya2018\plug-ins\MASH\scripts\flux\ui
    C:\Program Files\Autodesk02\Maya2018\plug-ins\MASH\scripts\flux\resources\icons
    C:\Program Files\Autodesk02\Maya2018\plug-ins\fbx\scripts
    C:\Program Files\Autodesk02\Maya2018\plug-ins\camd\scripts
    C:\solidangle\mtoadeploy\2018\scripts
    C:\Program Files\Autodesk02\Maya2018\plug-ins\substance\scripts
    C:\Program Files\Autodesk02\Maya2018\plug-ins\xgen\scripts\cafm
    C:\Program Files\Autodesk02\Maya2018\plug-ins\xgen\scripts\xgenm
    C:\Program Files\Autodesk02\Maya2018\plug-ins\xgen\scripts\xgenm\ui
    C:\Program Files\Autodesk02\Maya2018\plug-ins\xgen\scripts\xgenm\xmaya
    C:\Program Files\Autodesk02\Maya2018\plug-ins\xgen\scripts\xgenm\ui\ae
    C:\Program Files\Autodesk02\Maya2018\plug-ins\xgen\scripts\xgenm\ui\brushes
    C:\Program Files\Autodesk02\Maya2018\plug-ins\xgen\scripts\xgenm\ui\dialogs
    C:\Program Files\Autodesk02\Maya2018\plug-ins\xgen\scripts\xgenm\ui\fxmodules
    C:\Program Files\Autodesk02\Maya2018\plug-ins\xgen\scripts\xgenm\ui\tabs
    C:\Program Files\Autodesk02\Maya2018\plug-ins\xgen\scripts\xgenm\ui\util
    C:\Program Files\Autodesk02\Maya2018\plug-ins\xgen\scripts\xgenm\ui\widgets
    C:\Users\Mingalll\AppData\Local\Programs\Python\Python36\lib\plat-win
    C:\Users\Mingalll\AppData\Local\Programs\Python\Python36\lib\lib-tk
Python Environment:
My erro above, please help me, I need work
RFlannery1
My best guess is that Maya is confused because it can't find the correct version of Python.  Specifically it needs to be able to find the Python files in its own installed directories.  I noticed that your PYTHONPATH contains some references to "Python36".  Try removing those and see if it works any better.
