Maya batch render
Hi there, I have several fbx/objs, that I want to render and create a preview for.
I'm using Maya 2025.
I am trying to write a script to test out cmd line rendering, however I keep getting an error message
as a test, i created the following mel file
// Define input FBX and output render paths
string $inputFile = "H:\\3D Models\\Aeroplanes\\AH-64D.fbx";
string $outputImage = "H:\\3D Models\\Aeroplanes\\AH-64D_preview.png";
// Import the FBX file
try
file -import -type fbx $inputFile;
print ("File Imported: " + $inputFile + "\n");
// Set up the render output file
int $renderWidth = 1920;
int $renderHeight = 1080;
// Set render settings (adjust as needed)
setAttr defaultRenderGlobals.imageFormat 1; // PNG format
setAttr defaultResolution.width $renderWidth;
setAttr defaultResolution.height $renderHeight;
setAttr defaultRenderGlobals.imageFilePrefix $outputImage;
// Render the scene
render -r;
print ("Rendering complete. Output saved to: " + $outputImage + "\n");
catch
print ("Failed to render file: " + $inputFile + "\n");
and then I try to run it with the following command prompt
"D:\Program Files\Autodesk\Maya2025\bin\mayabatch.exe" -file "H:\3D Models\Aeroplanes\import_and_render.mel"
Access is denied.
I get a windows popup error saying This app cant run in your pc.
can anyone provide any suggestions on how to fix this?
Also I want to update the script to go thru multiple folders/sub folders and find any fbx,obj, maya files and render them.
I have about 1000+ folders with sub/sub folders
