Maya 2022- pymel - how to import ?
Bob.Bon2000
Message 1 of 9
Bob.Bon2000
Hiay
All I get is >> `# Error: ModuleNotFoundError: file C:\Program Files\Autodesk\Maya2022\Python37\lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py line 142: No module named 'pymel'`
How do we import the thing to maya?
TIA
Replies (8)
Message 2 of 9
negow
PyMEL is an optional item when you install Maya 2022, you could run the installer again and tick the PyMEL box to install it.
Message 3 of 9
batarg
lets check if its really installed:
navigate to maya installation folder find folder bin select it and while holding down shift press rmb  to open modified context menu from there find and click "open in powerShell".
then just type mayapy and press [TAB] (it will expand like .\mayapy.exe) then continue typing " -m pip list":
PS <installed_path>Maya2022\bin> .\mayapy.exe -m pip list
and press enter
if you will get something like this
future 0.18.2
pip 20.2.2
PySide2 5.15.2
setuptools 41.2.0
shiboken2 5.15.2
shiboken2-generator 5.15.2
*(there is no pymel)
then you need to install it this way:
.\mayapy.exe -m pip install pymel
after installation is complete you can check it again:
you should get something similar:
future 0.18.2
pip 21.2.2
pymel 1.2.0
PySide2 5.15.2
setuptools 41.2.0
shiboken2 5.15.2
pymel is now installed!
you're ready to go! no need to modify PATH environment variable
bonus:
if you receive message that new version of pip installer is available and if you wish to upgrade it use this cmd:
.\mayapy.exe -m pip install --upgrade pip
pip install its just convenient way to get python packages as easy as snap of the fingers :tanos_envy:
Message 4 of 9
Hans_Redman
Thanks man, it worked!
Message 5 of 9
francescoHVGX5
Thank you for this !! ... Why the hell does Maya 2024 does not install pymel by default ?!
Message 6 of 9
Oleg.Gogolushko.2397
Community Visitor
Community Visitor
Thank you wery much!!! It works!!)
Message 7 of 9
tyler_thornock536PA
Community Visitor
Community Visitor
Finally, they removed pymel 😄
Message 8 of 9
matpar_
Community Visitor
Community Visitor
awesome, that helped! thanks!
Message 9 of 9
719958768
Community Visitor
Community Visitor
没看懂?
