Hello all,
I'm posting this in the programming forum because that's the level that I'm guessing my issue is on. In python, when I call urllib2.urlopen (edit: or urllib.urlopen), Maya hard crashes - not even a fatal error window, it's just gone. Not absolutely every endpoint causes the crash, but many do. You may think the obvious answer is to not use urllib2.urlopen, but it's a plugin that's doing it so not really up to me. Bizarrely, this only happens on my new computer but not my old one. It's a new PC so Windows is freshly installed, and I have re-installed Maya several times now. It crashes in headless mode too - mayapy.exe will die if I run:
import urllib2
urllib2.urlopen("https://www.google.com")
Anybody ever seen something like this before?
Solved by techXVCP5. Go to Solution.
Some animators started having the issue. After looking around I think there is a conflict with 11th gen intel processors and Maya 2020's python SSL library. That's above my pay grade so I have just commented out all urllib requests in our plugins. I sure hope we don't end up needing them.
