Maya 2020.1 selected vertex in pymel returns Attribute
formjune
formjune
Does anyone knows why Autodesk had decided to replace return of MeshVertex with Attribute("mesh.pnts[i]") for single vertex in pymel? Problem remains for CVs end EPs as well.
And how to manipulte with them now as unlike vertex class attribute contains local position only? For Maya 2020 everything is ok, problem is 2020.1 only
sss
brentmc
I am pretty sure we are aware of the issue (and it should be fixed in the next update) so if you provide a sample script I can confirm.
Thanks.
Brent
Brent McPherson
Principle Software Developer
formjune
Thank you for reply!
import pymel.core as pm
plane = pm.polyPlane()[0]
pm.select(plane.vtx)
pm.selected()[0].getNormal("world") # works like in 2020
pm.select(plane.vtx[0])
pm.selected()[0].getNormal("world") # broken in 2020.1
Andrey
sss
brentmc
Hi Andrey,
Thanks for the script. I can confirm that this is the same issue and it will be addressed in a future update.
Thanks.
Brent
Brent McPherson
formjune
Just have checked in Maya 2020.2 and it works again! Thank you!
sss
brentmc
You're welcome. Thanks for following up!
Brent
Brent McPherson
