Load variables from a text file (MEL)?
hello everyone, I need your help.
As indicated in the title, I want to load variables from a text file. I'm writing a single script.
At first, I generate a text file "C:/tmp/variable.txt" , (with a fopen) in which there is this:
string $VARMAX[] = {"nurbsSphere1","pCube1","nurbsCone2"};
secondly, I load it:
source "C:/tmp/variable.txt";
print $VARMAX;
it is now that the problem happens. If my file "C:/tmp/variable.txt" doesn't yet exist, Maya will tell me  'Cannot find file'. Logic.
So I try to put the command in a 'evalEcho',
pause -sec 1;
evalEcho "source \"C://xdk//variable.txt\";";
print $VARMAX;
I have this message: // Error: Line 3.14: "$VARMAX" is an undeclared variable. //
as if it was a procedure.
I need to have this text file to use it instantly or later.
vijaya.prakash
Before executing the "source" command, you can get the file existing status using "filetest" command. Below is the exmaple:
if (`filetest -f "C://tmp//variable.txt"`) {
source "C://tmp//variable.txt";
print $VARMAX;
SimonJWakley
You could read out of the file and assign the line to you variable
// Here read them off disk if the file exists
// Open the file
// If we have a home directory, use that otherwise forget about it
string $setfile = getenv("HOME");
string $VARMAX[];
if (size($setfile))
    $setfile += "/myfile.txt";
    // Open the file
     $fileId = `fopen $setfile "r"`;
if ($fileId != 0)
    $varmax = `fgetline $fileId`;
    // "nurbsSphere1","pCube1","nurbsCone2" read from file hopefully 🙂
    fclose($fileId);
Not sure if it works or gives you what you want, but that's what I 'd try!
Simon
