Isolate selection and objectSets
mcw0
Advisor Advisor
mcw0
When a selection is isolated in a panel, an objectSet is created.  What is special about that objectSet that Maya knows to use it for isolating in a panel?  Why not use any other objectSet that exists in the scene?  I'm not seeing any special connections.
Kahylan
Hi!
This is quite complex, and to be honest it's too far under the hood for me to really access it.
Here is what I can tell you about it:
How isolate selection functions and what is created/deleted when the button is activated/deactivated is handlet by a internal mel procedure  called "modelPanelBarIsolateSelectCallback" which runs on the change command of the iconTextCheckBox "isolateSelectBtn".
#Python Query for chancecommand on isolate select button
iconTextCheckBox("MainPane|viewPanes|modelPanel4|modelPanel4|modelEditorIconBar|flowLayout6|formLayout46|IsolateSelectedBtn", q=True, cc = True )
#Result
modelPanelBarIsolateSelectCallback("IsolateSelectedBtn", "MainPane|viewPanes|modelPanel4|modelPanel4|modelPanel4", "MainPane|viewPanes|modelPanel4|modelPanel4|modelEditorIconBar"); restoreLastPanelWithFocus();
Sadly when looking for this procedure on my computer I couldn't find anything and googling for it only gave me wrap functions that call this function as is...
My guess is that this function creates either a global variable that stores the information as to which modelpanel belongs to which set, or the information is stored somewhere on a hidden UI element withing MainPane or viewPanes.
Now, I honestly never looked into this before today, because whenever I needed to find the objetSet that is connected to a modelPanel, I just used the "isolateSelect" command to query it.
string $mP = "modelPanel4";
string $vo = `isolateSelect -q -vo $mP`;
print($vo)
Could that might be helpful for what you are trying to do?
mcw0
@Kahylan
Thanks for looking into this.  I was too tired to go digging through scripts yesterday.  I thought that if I changed the objectSet membership, that what was isolated would also change.  Not the case.  Nothing I did would isolate what I wanted, when I wanted.  But late in the day, a light bulb went off.  Instead of dealing with isolating geo, I just hid everything else.  Much easier and works every time.
Actually, now that I think about it, there could be a snag in this approach.  If there are connections on visibility either on the transform or the shape node.  But that can also be dealt with.
