Is there a way to define callback when a script window closes
e_juma
e_juma
In the document for script command 'window'. it only has a callback for minimize. But there is no way to set a callback when window close. Who knows how to make it?
korama20
I’m also looking for an answer to this question.
malcolm_341
Yes you define it in the window creation like this
window -title myWindow -sizeable true -resizeToFitChildren true -closeCommand "myGlobalProc();" myWindow_name;
malcolm_341
Sure it looks like this, but the myGlobalProc was just a dummy procedure to do whatever you want, rename it and put whatever code you want to execute in there.
global proc myGlobalProc()
     print "You closed the window\n";
Hans_Redman
malcolm_341
It won't, the name of this thread is "Is there a way to define callback when a script window closes" that code will run when the window closes. There's nothing mentioned in this thread about saving preferences. Are you a bot maybe?
