Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
Invalid syntax
1 REPLY 1
roshanshilimkar3434
284 Views, 1 Reply
Invalid syntax
Hey, I am new to programming and following a tut for creating a blank window using python, I've started maya 2022 with python2, what am I doing wrong? this is the exact code used in the tutorial
from PySide2 import QtCore
from PySide2 import QtWidgets
class TestDialog(QtWidgets.QDialog):
def_init_(self, parent=None):
super(TestDialog, self)._init_(parent)
if_name_ == "_main_":
d = TestDialog()
d.show()
thank you.,
1 REPLY 1
Hi!
You're missing the spaces after "def" and "if".
    def _init_(self, parent=None):
        if _name_ == "_main_":
            d = TestDialog()
            d.show()
I hope it helps!
