Invalid Syntax Error in Maya 2022
3d160emiliano
Observer Observer
3d160emiliano
Observer
Observer
Hello everyone!
I am trying to use a script to automate the turn-on of the Visibility on Redshift for all selected objects. But every time I run it it says "Syntax Error".
import maya.cmds as cmds
def set_visibility_overrides():
# Get the selected geometries
selected_geometries = cmds.ls(selection=True, dag=True, shapes=True)
for geometry in selected_geometries:
# Check if the geometry has the attribute "rsEnableVisibilityOverrides"
if cmds.attributeQuery("rsEnableVisibilityOverrides", node=geometry, exists=True):
# Set the value of "rsEnableVisibilityOverrides" to 1
cmds.setAttr(geometry + ".rsEnableVisibilityOverrides", 1)
print("Set rsEnableVisibilityOverrides to 1 for:", geometry)
else:
print("Attribute 'rsEnableVisibilityOverrides' not found for", geometry)
# Call the function
Can anyone spot the error? Or is it just a thing of my Maya preferences?
Thank you in advance!
Kahylan
Hi!
Here is the code with the right indentation levels, if someone else wants to reproduce the issue:
        else:
# Call the function
I can't say for sure, because you didn't post the full error message.
But my guess is, that you are not running it from a correct place in Maya. This is a Python script, so it needs to be run from a place that Maya looks at as being Python.
1) Python Tab in the Script editor
2) A shelfbutton that is set to be read as Python
3)A shortcut that is set to be read as Python
You probably accidentally ran it from a MEL Tab or from a shelfbutton/shortcut that is set to be read as MEL. Which would result in the Following error message:
// Error: def set_visibility_overrides(): //
// Error: Line 3.30: Syntax error //
If you have a Python synthax problem, and I accidentally fixed it somehow, the error message would look like this:
# Error: invalid syntax #
If you have the first error message, run it from one of the places I mentioned above and you should be fine
I hope it helps!
