Installing Tween Machine on MacOS
rojomerc
rojomerc
Community Visitor
Community Visitor
I'm trying to install the tween machine on an Apple Macbook, and can not find any resources online to approach it? My Maya file does not contain a script folder nor an icon/prefs folder. Do I create my own? I've attached a picture to show what Maya looks like when opened.
Kahylan
Hi!
Thats because you are in the wrong maya folder. You need your Maya Prefrences Folder not your Maya Application folder.
The folder you are looking for is located at:
Users/Library/Prefernces/Autodesk/Maya/NumberOfYourVersion/scripts
To get to that folder, you need to open the finder, then click on "Go To", when you have that dropdown menu open you hit the ALT/Option key,this will make the Library Folder appear. Form there on out it's just opening the file path.
Or you can use the "Go to folder" option as demonstrated in this tutorial at 0:52:
https://www.youtube.com/watch?v=NFBKtknP8Zo
I hope this helps!
