Import/Export Batch
Import/Export Batch
Import/Export Batch
I am wondering if anyone has written or knows of a tool to allow a user to import multiple *.obj or *.stl etc files into maya.
Clicking “file import” three times for three imports into the scene is fine but more than ten?
If you open the Script Editor and then do a File -> Import and look at the output - this is MEL script that you can generalise and then create your own new scripts.
It outputs something like this:
pv_performAction "C:/export.obj" "Best Guess";
file -import -type "OBJ" -ra true -namespace "export" -pr -loadReferenceDepth "all" "C:/export.obj";
Now just loop through your files and use the code above.
