Hi everyone
I need to open some large/messy scenes from other artists. It always prompts out a lot of warnings and freezes Maya for a long time. I try to write a custom "open file" with python to suppress warning messages. But it seems not really "mute" script editor entirely. Let's say, when I open Hypershade window after open file, warnings prompt out again since I have lots of missing textures. The script I use now is:
import maya.cmds as cmds import maya.mel as mel filename = cmds.fileDialog2(fileMode=1) reporter = mel.eval( 'string $tmp = $gCommandReporter;' ) cmds.scriptEditorInfo(reporter,suppressWarnings=True,suppressInfo=1,se=1,ch=1) cmds.disableIncorrectNameWarning() cmds.file( filename[0], i=True );
Not sure if I use this API correctly, Many thanks for your advice.
Thank you
Solved by aboutvenice. Go to Solution.
hi,
Try this....
In the Script Editor, turn off History > Echo All Commands.
Hi. it's not working, warning and error are not effect by this option.
And I expect to use a script instead of menu action.
Finally, succeed. So basically this works:
import maya.cmds as cmds cmds.scriptEditorInfo(suppressWarnings=0,suppressInfo=0,se=0)
The reason I couldn't get it to work is that I use Charcoal Editor for Maya to write python. It somehow not suppress warnings. After I unload it everything is ok.
http://help.autodesk.com/cloudhelp/2016/CHS/Maya-Tech-Docs/CommandsPython/
The document doesn't mention the default value but I guess you can query the flag value before you do any changes.
import maya.cmds as cmds info = cmds.scriptEditorInfo(query=True, suppressInfo = True) print(info)
You also can try this: History > Suppress Warning Messages.
Hope this helps
Store the settings of the scriptEditor window in a dictionary called "state":
flags = ["se", "si", "sr", "sw", "ssw"]
state = {}
for x in flags:
kwargs = {"q" : True, x : True}
val = maya.cmds.scriptEditorInfo(**kwargs)
state[x] = val
print(state)
Do your settings. In my case, I want to suppress warnings
maya.cmds.scriptEditorInfo(e=True, sw=True)
Then reset things back to the way they were:
for x, val in state.iteritems():
kwargs = {"e" : True, x : val}
You may want to clear the stack before you do this, it can chugalug a bit if you've got a long history.
