How to send python lists to a custom command
dneag
dneag
I'd like to be able to create a command that will accept from python a large list, or even better a list of tuples, as an argument. Just like the curve command for instance: cmds.curve( d=1, p= [ (x,y,z), (x,y,z), (x,y,z), ... ] ).  And then translate it into a multidimensional array.
I can use the addFlag and flagArgument functions to pass data through, but the data types seem limited.
Here is what I have:
MSyntax MyCommand::newSyntax()
    MSyntax syntax;
    syntax.addFlag( "-arg", "-argument", MSyntax::kDouble);
    return syntax;
MStatus MyCommand::doIt(const MArgList &argList)
    MStatus status;
    MArgDatabase argData(syntax(), argList, &status );
    CHECK_MSTATUS_AND_RETURN_IT(status);
    double arg1;
    arg1 = argData.flagArgumentDouble("-arg", 0);
How can I make a command that accepts lists as arguments?
RFlannery1
I think you can get it to accept a list by using the "makeFlagMultiUse" command from the MSyntax class.  So if you wanted a list of strings, you would do the following:
MSyntax syntax;
syntax.addFlag( "-arg", "-argument", MSyntax::kString);
syntax.makeFlagMultiUse("argument");
Less sure about a list of tuples.  I would guess something like this:
MSyntax syntax;
syntax.addFlag( "-arg", "-argument", MSyntax::kDouble, MSyntax::kDouble, MSyntax::kDouble);
dneag
Well that does seem to allow the command to accept a list but I can't figure out how/if I can access all the elements on the other end.
I'm doing this:
MSyntax CreateMesh::newSyntax()
    MSyntax syntax;
    syntax.makeFlagMultiUse("-arg");
    return syntax;
MStatus CreateMesh::doIt(const MArgList &argList)
    MStatus status;
    MString arg1, arg2;
    arg1 = argData.flagArgumentString("-arg", 0);
    arg2 = argData.flagArgumentString("-arg", 1);
    MGlobal::displayInfo("Your list is: "+arg1+", "+arg2);
After running the command with a list of two strings ["a","b"], the arg1 variable will take the first element of the list, but arg2 remains empty.  I took a guess that the int parameter of flagArgumentString might correspond to the elements of the list but that doesn't seem to be working.
RFlannery1
Thanks for correcting my syntax.  I wasn't sure of the exact string to pass into the "makeFlagMultiUse" function.
Anyways, I found some examples in the devkit, AbcBullet.cpp and geometryCacheConverter.cpp.  Here is a slightly modified snippet of code from geometryCacheConverter:
#define SFLAG_FILE "-f"
MStatus convertGeometryCache::doIt( const MArgList& args ) MStatus status = MS::kSuccess; MArgDatabase argDb( syntax(), args, &status ); if( !status ) return status; bool hasFile = argDb.isFlagSet( SFLAG_FILE ); if( !hasFile ) { MGlobal::displayError( "Specify at least one file." ); return status; } // Iterate through all the files specified // uint numUses = argDb.numberOfFlagUses( SFLAG_FILE ); for( uint i = 0; i < numUses; i++ ) { MArgList argList; status = argDb.getFlagArgumentList( SFLAG_FILE, i, argList ); if( !status ) return status; MString name = argList.asString( 0, &status ); if( !status ) return status; } }
dneag
Aha!  This is working.  Although I don't totally understand how.
I guess any list sent through has to be treated as a separate MArgList?
Also, from there, a list of tuples is pretty straightforward:
    MSyntax syntax;
    syntax.addFlag( "-arg", "-argument", MSyntax::kDouble, MSyntax::kDouble, MSyntax::kDouble );
    return syntax;
    MStatus status;
    uint numUses = argData.numberOfFlagUses("-arg");
        MArgList argList;
        status = argData.getFlagArgumentList( "-arg", i, argList );
        double d1 = argList.asDouble( 0, &status );
        double d2 = argList.asDouble( 1, &status );
        double d3 = argList.asDouble( 2, &status );
        MGlobal::displayInfo(MString()+d1+", "+d2+", "+d3);
Not sure what a uint is or what its purpose here is.  Regular int seems to work as well.
Anyways, thank you very much.
