How to assign a dictionary of key/value render settings from json to Maya's render settings
craig_kane
craig_kane
Hi
I want to apply a dictionary of key/value data from a json file into Maya's render settings.
Currently, I have a dictionary of 16 items formatted as follows:
{u'defaultRenderGlobals.blurSharpness': 1.0, u'defaultRenderGlobals.enableDefaultLight': False}
I am unsure how exactly I should loop through the data and assign it all to the correct attributes inside Mata using cmds.setAttr() command.
Could anyone suggest a good method to assign them all? I am aware that Maya recommends it's own function to load the full render setup json, but here I am looking for a way so assign only certain arrays as required. For instance, I might only want to assign the settings values from all defaultRenderNodes.
Thank you,
Craig
Kahylan
Hi!
First you need to import your dict from the json file.
Then you either iterate through keys and then call values in the loop:
import maya.cmds as mc
dict = importedDictionary
for key in dict:
    cmds.setAttr(key,dict[key])
Or you unpack your dict with the .items() function first:
for key,value in dict.items():
    cmds.setAttr(key,value)
The second is considered more readable and pythonic, but it doesn't really make a difference.
I hope this helps!
craig_kane
Thanks Kahylan, worked perfectly! Appreciate the help.
