How to access a custom shared lib on Linux?
Message 1 of 1
Our plug-in needs to access some custom shared libraries, which we provide in our installer. The Maya developer docs say:
If a C++ plug-in links to a custom shared library, special steps must be taken.
  • Windows: The shared library (ending in .dll) must go into either Maya's own bin directory or one of the directories in the user's PATH environment variable.
  • Linux: The library (ending in .so) must go into either Maya's own lib directory or one of the directories in the user's LD_LIBRARY_PATH environment variable.
I'd like to avoid cluttering up Maya's directory tree if at all possible, but I don't want the user to have to fiddle with their LD_LIBRARY_PATH envariable either.
For a Windows plug-in a module-specific folder can be added to PATH using the following syntax in the module file:
    PATH+:=lib
and that works, allowing us to keep the custom DLLs in the 'lib' sub-directory of the folder containing our module. But if I try the same thing on Linux:
    LD_LIBRARY_PATH+:=lib
it doesn't work.
Does anyone have a workaround for this? Or are we stuck putting the shared libs into Maya's tree?
Replies (0)
