How do I query the current tool context in Mel?
malcolm_341
malcolm_341
This doesn't work, what am I missing here?
string $currentToolName = `currentCtx`;
int $userToolMode = `manipMoveContext -q -mode $currentToolName`;
Rourker27
"manipMoveContext -mode" is looking for an int not the name of your current tool. What is it you are trying to do?
edit: Oh, this is a query, so you are trying to find the translation mode of your current tool?
brentmc
When dealing with tools like select/move etc. there are special contexts called "super contexts" which decide, based on the view, which context should process the mouse events. This is used to handle the fact that the actual select tool in the 3D view is different from the one in the UV editor etc.
The great news is there are lots of Mel scripts that ship with Maya and you can poke around those to see how things are done.
This example shows how bakeCustomToolPivot.mel decides if the move tool is active. It first checks the context and then just pulls the values from the "Move" tool. (since the move tool is always called "Move" in Maya)
string $currentCtx = `currentCtx`;
if ($currentCtx == "moveSuperContext"   || $currentCtx == "manipMoveContext") {
	// Move tool
	$customOri = `manipMoveContext -q -orientAxes Move`;
Brent
Brent McPherson
Principle Engineer
Thanks for your replies, I'm trying to store the user's current select tool and then bring it back later after my script has finished so they don't lose their current tool mode. I was hoping a could do this with a query and then set that mode at the end of the script, I got it working, but this feels like more code than should be required to do something like this. Is there an easier solution?
//Store current tool
string $currentToolActive = `currentCtx`;
//Do some stuff here
//Bring back user tool
if(`gmatch $currentToolActive "*selectSuperContext*"`)
	SelectTool;
if(`gmatch $currentToolActive "*lassoSelectContext*"`)
	LassoTool;
if(`gmatch $currentToolActive "*artSelectContext*"`)
	artSelectToolScript 4;
if(`gmatch $currentToolActive "*moveSuperContext*"`)
	MoveTool;
if(`gmatch $currentToolActive "*RotateSuperContext*"`)
	RotateTool;
if(`gmatch $currentToolActive "*scaleSuperContext*"`)
	ScaleTool;
brentmc
If you just want to save and restore the tool you can use the setToolTo command like this:
setToolTo $currentToolActive;
Brent
Brent McPherson
Principle Engineer
malcolm_341
Yes that's it, that's exactly what I was looking for. Thanks!
