How can I get the object under the cursor without selecting it?
143110913
143110913
I'm working on a custom context and would like to know which object is under my cursor every time it moves. (MPxContext::doPtrMoved)
- Since it can be potentially be hundreds of objects, I think any kind operation that checks intersections with MFnMesh are discarded.
- I also can't seem to use MGlobal::selectFromScreen since that makes with my custom drawing blink. (Unless I'm missing something)
Right now I'm using maya.cmds.hitTest but I wonder if there's an equivalent on the API.
Thanks!
Just adding that cmds.hitTest is very unreliable, it doesn't always recognize a mesh so I can't really use it.
I think I see the error.
MEvent.getPosition( x, y ) returns possibly incorrect coordinates.
If I use Qt/PySide to read the cursor position it does work properly.
pos = QtGui.QCursor.pos()
widget = QtGui.qApp.widgetAt(pos)
relpos = widget.mapFromGlobal(pos)
Is there any offset inside MEvent that I have to take into account or that I'm missing?
I found the solution.
On Qt 0 on the Y axis starts at the lower corner, on MEvent at the top.
I'll still leave this open for a few days in case there's a better way to do this than hitTest.
Thank you!
jmreinhart
So MGlobal::selectFromScreen actually uses the same calculations as the MFnMesh intersect functions, so I wouldn't rule that out as an option without at least testing it's speed with a lot of objects.
If you're ok with posting the part of your code where you encounter flickering we may be able to resolve that too.
Hi Jonah,
Thank you for your reply,
I've prepared a simplified example of my doPtrMoved Fn.
I'd like to get what object is under the mouse and based on that draw some faces.
Calling MGlobal::selectFromScreen will make my custom drawing flicker.
MStatus CustomContext::doPtrMoved(MEvent &event, MUIDrawManager &drawMgr, const MFrameContext &context) {
ptArray.clear();
ptArray.append(MPoint(0, 0, 0));
ptArray.append(MPoint(-10, 0, 0));
ptArray.append(MPoint(-10, 0, 10));
MSelectionList incomingList;
MGlobal::getActiveSelectionList(incomingList);
MGlobal::selectFromScreen(0, 0, MGlobal::kReplaceList);
MSelectionList screenMSel;
MGlobal::getActiveSelectionList(screenMSel);
// Restore the active selection
MGlobal::setActiveSelectionList(incomingList, MGlobal::kReplaceList);
drawMgr.setPaintStyle(MUIDrawManager::kStippled);
drawMgr.beginDrawInXray();
drawMgr.mesh(MUIDrawManager::kTriangles, ptArray);
drawMgr.endDrawInXray();
return MStatus();
Since this is for hundreds of meshes, it is considerable faster to get which mesh is under my mouse with MGlobal::selectFromScreen than instantiating an MFnMesh object with each of those meshes and using MFnMesh::anyIntersection
Let me know if I'm missing anything.
Thanks.
jmreinhart
So it seems like the selectFromScreen causes flickering because it causes a refresh of the viewport. I don't know if there is a way to use that function and get around it.
I did do some testing of my own using the MfnMesh method and I was getting some good results using some optimization.
  • Updating the maxParam whenever you find an intersection on a mesh, so the other meshes we check will only need to search a shorter distance.
  • Get the list of meshes in ToolOnSetup and create MMeshIsectAccelParams for them
I did notice that the M3dView class has a beginSelect and endSelect which seems graphics-based? But I didn't really dig into it.
Sorry for the janky test code
#include <maya/MString.h>
#include <maya/MItSelectionList.h>
#include <maya/MPxContextCommand.h>
#include <maya/MPxContext.h>
#include <maya/MPxSelectionContext.h>
#include <maya/MEvent.h>
#include <maya/M3dView.h>
#include <maya/MObjectArray.h>
#include <maya/MDagPathArray.h>
#include <maya/MIntArray.h>
#include <maya/MGlobal.h>
#include <maya/MFnPlugin.h>
#include <maya/MPointArray.h>
#include <maya/MUIDrawManager.h>
#include <maya/MItDag.h>
#include <maya/MDagPath.h>
#include <maya/MFnDagNode.h>
#include <maya/MFnMesh.h>
#include <maya/MFnCamera.h>
#include <vector>
class clickTest : public MPxContext
public:
	clickTest() {};
	virtual                 ~clickTest() {};
	void*                   creator() {};
	void    toolOnSetup(MEvent & event);
	MStatus doPress(MEvent &event, MHWRender::MUIDrawManager &drawMgr, const MHWRender::MFrameContext &context) { return MS::kSuccess; }
	MStatus doDrag(MEvent &event, MHWRender::MUIDrawManager &drawMgr, const MHWRender::MFrameContext &context) { return MS::kSuccess; }
	MStatus doRelease(MEvent &event, MHWRender::MUIDrawManager &drawMgr, const MHWRender::MFrameContext &context) { return MS::kSuccess; }
	MStatus doPtrMoved(MEvent &event, MHWRender::MUIDrawManager &drawMgr, const MHWRender::MFrameContext &context);
	MPointArray ptArray;
	MDagPathArray allMeshes;
	std::vector<MMeshIsectAccelParams> accels;
// Command to create contexts
class meshReorderContextCmd : public MPxContextCommand
public:
	meshReorderContextCmd() {};
	virtual MPxContext* makeObj();
	static void*            creator();
MPxContext* meshReorderContextCmd::makeObj()
	return new clickTest;
void* meshReorderContextCmd::creator()
	return new meshReorderContextCmd;
bool isVisible(MFnDagNode dagNodee, MStatus status)
	return true;
MStatus getAllMeshes(MDagPathArray& pathArray)
	MStatus status;
	//create an iterator for only the mesh components of the DAG
	MItDag itDag(MItDag::kDepthFirst, MFn::kMesh, &status);
	if (MStatus::kFailure == status) {
		MGlobal::displayError("MItDag::MItDag");
		return MS::kFailure;
	pathArray.clear();
	for (; !itDag.isDone(); itDag.next()) {
		//get the current DAG path
		MDagPath dagPath;
		if (MStatus::kFailure == itDag.getPath(dagPath)) {
			MGlobal::displayError("MDagPath::getPath");
		pathArray.append(dagPath);
		//if this node is visible, then process the poly mesh it represents
		// IGNORE FOR NOW
	return MStatus::kSuccess;
void  clickTest::toolOnSetup(MEvent & event)
	getAllMeshes(allMeshes);
	accels.resize(allMeshes.length());
	for (unsigned i = 0; i < allMeshes.length(); i++)
;		accels[i] = MFnMesh(allMeshes[i]).autoUniformGridParams();
MStatus clickTest::doPtrMoved(MEvent &event, MHWRender::MUIDrawManager &drawMgr, const MHWRender::MFrameContext &context)
	MStatus status;
	M3dView view = M3dView::active3dView();
	short x_pos;
	short y_pos;
	event.getPosition(x_pos, y_pos);
	ptArray.clear();
	ptArray.append(MPoint(0, 0, -10));
	int method = 1;
	if (method == 0)
		MGlobal::selectFromScreen(x_pos, y_pos, MGlobal::kReplaceList, MGlobal::kSurfaceSelectMethod);
	else if (method == 1)
		// Is having this in tool on setup an option?
		// Sluggish at 1000 spheres
		MDagPath dagPath;
		view.getCamera(dagPath);
		MFnCamera camFn(dagPath);
		MPoint raySource;
		MVector rayDirection;
		view.viewToWorld(x_pos, y_pos, raySource, rayDirection);
		float maxParam = camFn.farClippingPlane();
		MFloatPoint nearestHit;
		MFloatPoint hitPoint;
		float minParam = maxParam;
		float hitRayParam = maxParam;
			MFnMesh mFnMesh(allMeshes[i]);
			mFnMesh.closestIntersection(raySource,
				rayDirection,
				NULL,
				NULL,
				true,
				MSpace::kWorld,
				minParam,
				false,
				&accels[i],
				hitPoint,
				&hitRayParam,
				NULL,
				NULL,
				NULL,
				NULL,
				status
			if (status != MS::kSuccess)
				continue;
			if (hitRayParam < minParam)
				minParam = hitRayParam;
				nearestHit = hitPoint;
		ptArray[2] = nearestHit;
	else if (method == 2)
	return MStatus();
// plugin initialization
MStatus initializePlugin(MObject obj)
	MStatus     status;
	MFnPlugin   plugin(obj, PLUGIN_COMPANY, "12.0", "Any");
	status = plugin.registerContextCommand(MString("marqueeToolContext"), meshReorderContextCmd::creator);
	return status;
MStatus uninitializePlugin(MObject obj)
	MStatus     status;
	MFnPlugin   plugin(obj);
	status = plugin.deregisterContextCommand("marqueeToolContext");
	return status;
import maya.mel as mel
cmds.file(new = True, f= True)
for i in range(10000):
    x = random.randint(-10, 10)
    y = random.randint(-10, 10)
    z = random.randint(-10, 10)
    s = cmds.polySphere()[0]
    cmds.setAttr(s + '.t', x,y,z)
cmds.loadPlugin('...')
x = cmds.marqueeToolContext()
mel.eval('setToolTo {}'.format(x))
