get bounding box in local space
Craig_Lamorte
Message 1 of 16
Craig_Lamorte
I am looking to get the bounding box size of an object in local space, not in world space.  So no matter which way the object is rotated it will always give me the same X, Y, and Z.
I did try this, but it only does it in world space.  (the object I am selecting is a group node with meshes underneath it
cmds.xform(mesh, bb=True, q=True, os=True)
I know I can also do this, but i dont see any flags to do local space, so it just returns in world space as well
cmds.getAttr("mesh.boundingBoxSizeX")
Are there any commands that will give me the bounding box in local space?
Craig
Replies (15)
Message 2 of 16
olarn
Message 3 of 16
hagen.deloss
Hi @Craig_Lamorte
I'm curious if you still need any tech support help, or if @olarn comment helped resolve the issue?
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 4 of 16
Craig_Lamorte
Still have not found a solution.  Tried looking at those links, looks like one of them using maya api, but I am not really sure how to use it, there aren't any examples, and documentation is confusing.
Message 5 of 16
hagen.deloss
@Craig_Lamorte
I was recommended this solution that may prove useful.
import maya.OpenMaya as OM
def Run():
# Get the current selection.
# The first object in the selection is used, and is assumed
# to be a transform node with a single shape directly below it.
selectionList = OM.MSelectionList()
OM.MGlobal.getActiveSelectionList(selectionList)
selectedPath = OM.MDagPath()
selectionList.getDagPath(0, selectedPath)
# Get the transformation matrix of the selected object.
transform = OM.MFnTransform(selectedPath)
m = transform.transformationMatrix()
# Get the shape directly below the selected transform.
selectedPath.extendToShape()
fnMesh = OM.MFnMesh(selectedPath)
bounds = fnMesh.boundingBox()
center = bounds.center()
min = bounds.min()
max = bounds.max()
print('Center: (%f, %f, %f)' % (center.x, center.y, center.z))
print('Min: (%f, %f %f)' % (min.x, min.y, min.z))
print('Max: (%f, %f %f)' % (max.x, max.y, max.z))
print('')
# Transform the bounding box min/max by the objects transformation matrix.
minTransform = min * m
maxTransform = max * m
print('Transformed Min: (%f, %f %f)' % (minTransform.x, minTransform.y, minTransform.z))
print('Transformed Max: (%f, %f %f)' % (maxTransform.x, maxTransform.y, maxTransform.z))
Run()
Found on this website here. It looks like this may take some knowledge in Python scripting.
Hagen Deloss
Message 6 of 16
olarn
In addition to @hagen.deloss  's solution, this is the MFnDagNode/MFnTransform version.
It's a standalone function, just give it transform node name and it will return tuple of min max point values.
(MFnTransform also gives out AABB)
I believe it will also gives:
  • AABB for any "shape" node other than mesh (nurbs, fluid container etc)
  • Cumulative bounding box at any point in the hierarchy without manual calculation.
import maya.api.OpenMaya as om2
def giv_transform_local_aabb_plz(partial_name):
    msellist = om2.MSelectionList()
    msellist.add(partial_name)
    try:
        trn_dag = msellist.getDagPath(0)
    except IndexError:
        return None
    local_bound = om2.MFnDagNode(trn_dag).boundingBox
    return (
            local_bound.min.x,
            local_bound.min.y,
            local_bound.min.z,
            local_bound.max.x,
            local_bound.max.y,
            local_bound.max.z,
def dewit():
    import pymel.core as pm
    print(giv_transform_local_aabb_plz(
        pm.ls(sl=1)[0].name()
dewit()
http://help.autodesk.com/view/MAYAUL/2019/ENU/?guid=Maya_SDK_MERGED_cpp_ref_examples_html
Message 7 of 16
Craig_Lamorte
Thanks for the examples.  I did try both of these and unfortunately it still seems to be giving me the world space bounding box.
I created a box, sized it to x = 50, Y = 75, Z = 100.  Ran the bounding box calculations and got this -
Transformed Min: (-25.000000, -37.500000 -50.000000)
Transformed Max: (25.000000, 37.500000 50.000000)
rotated the box by 45 degrees on the Y and got -
Transformed Min: (-53.033009, -37.500000 -17.677670)
Transformed Max: (53.033009, 37.500000 17.677670)
I was hoping it would be the same result, because the dimensions of the box did not change and if it is rotated at weird angle, I would like to know the actual dimensions of the object, and not of a box put around it.
Message 8 of 16
hagen.deloss
@Craig_Lamorte
I got another suggestion from the Maya development team, not sure if this has been suggested before, but doesn't hurt to post it anyway 😄
Try querying all of the components instead of the shape itself.
e.g. If mesh = "pCube1"
Instead of this:
Try this:
cmds.xform(mesh+".vtx[*]", bb=True, q=True, os=True)
Let me know if you have follow up questions!
Hagen Deloss
Message 9 of 16
Craig_Lamorte
Tried it, and it only seems to give me this no matter the size
[-0.5, -0.5, -0.5, 0.5, 0.5, 0.5]
Message 10 of 16
olarn
That might have been the true bounding volume of your shape, in (untransformed) object space.
Transformation effects scale too, not just translation and rotation.
Message 11 of 16
olarn
It is axially-aligned so the shape changes as the object rotate
https://www.youtube.com/watch?v=C8jyLB9ji6g
Local in this sense means it's measured against immediate parent's axis, not the scene.
Message 12 of 16
Craig_Lamorte
ah yeah, I was hoping there was a way to get a bounding box that is not axially-aligned.  A bounding box that would rotate with an object.  Not sure if this is even possible.
Message 13 of 16
hagen.deloss
Hi @Craig_Lamorte
It sounds like @olarn is spot on regarding the bounding box reflecting the objects current dimensions. It may be possible for the development team to implement a tool like you are describing in later releases though! I would recommend posting to the Maya Ideas forum here so others can vote on this feature suggestion 😄
Best of luck on your project!
Hagen Deloss
Message 14 of 16
mspeer
Hi!
Not sure what's the problem here, but this gives me correct local space data and ignores transform values of the transform node as these are shape only data. Of course this has to be used with the Shape node only.
cmds.getAttr("Shape.boundingBoxMinX")
cmds.getAttr("Shape.boundingBoxMinY")
cmds.getAttr("Shape.boundingBoxMinZ")
cmds.getAttr("Shape.boundingBoxMaxX")
cmds.getAttr("Shape.boundingBoxMaxY")
cmds.getAttr("Shape.boundingBoxMaxZ")
Please show me an example scene where this does not work.
Message 15 of 16
olarn
Seems like you wanted the "boundingBox" the way it's displayed in viewport bounding box override?
Volume-bound to untransformed to shape but moved, rotate, scaled to expected object position(but in local space)?
Then @hagen.deloss 's first solution would probably be the nearest to what you wanted. (you have to make out the rest of the box corners on your own)
These "boundingBox" are only useful for visualization tho. To detect intersection etc you still have to get either the normal AABB or transform back to object space..
Message 16 of 16
abasarabUSBZV
Community Visitor
Community Visitor
wow! Thank you that's works for my case!!
