Finding a shape (DAG) node through the DG
I have a MPxNode, which has some outMesh Plug for kMesh objects.
When i connect a shape node there, I can get its DagPath with MDagPath::getAPathTo(otherPlug.node(), dagPath) in the connectionMade function.
When i now use some operation creating DG nodes (i.e. CreateColorSet nodes), i cannot find the shape node anymore. getAPathTo fails, MItDependencyGraph(otherPlug.node(), MFn::kMesh) doesn't find anything as well.
(MItDependencyGraph cannot be used with otherPlug directly, as it's const in the connectionMade callback).
How can i reliably find a shape, which is somewhere in the downstream of a output plug?
This is the structure I get with my fieldGen node.
I am creating the node and the output shape myself in a MPxCommand, then I create two colorsets. Now the node is reconnected to the first of the colorsets and I have no idea if the connections end on the same shape as before.
