Find object with no UV coordinates
I'm writing a Python script to determine if an object has UV coordinates or not. - by counting the UVshells.
This should be straight forward.
import maya.cmds as cmds
cmds.cube( n ='cubey' )
# number of UV shells
UV = cmds.polyEvaluate( uvShell=True )
print UV
Only I get the error:
TypeError: file <maya console> line 6: Invalid flag 'uvShell' #
So I'm a little confused since the above is used as an example in the docs😲
mspeer
Hi!
What Maya version are you using?
Here it works, except for your cube creation which should be
cmds.polyCube( n ='cubey' )
Maya 2017
mspeer
Hi!
Please check the documentation, Maya 2017 does not support this flag,
it was added in Maya 2018.
So you need to use Maya 2018 or any other script.
I recommend to try
cmds.polyEvaluate( uvcoord=True )
If the result is "0", there are no UV coordinates (for the current UV Set) and this also works in Maya 2017
olarn
Would counting the number of UV points instead works in your case?
import pymel.core as pm
obj = pm.PyNode("pTorus1").getShape()
has_any_uv_current_set = obj.numUVs() > 0
print(has_any_uv_current_set)
That may wee work, the minor adjustment in the code above works for me 🙂
