Exclude a material from Maya Software renderer's anti-aliasing
morinnicolas8944
morinnicolas8944
I am working on a toon shading material and would like to give the user an option to keep it from being anti-aliased by the Maya Software renderer.
As shown in the attached image, the edges of objects where the material is applied are anti-aliased against the background and I would like to be able to disable this for my material.
Is this possible?
Thanks!
tony.su
Autodesk Support
Autodesk Support
There is one global setting for anti-aliasing of Maya software rendering. I don't think you can exclude a material. You can use layer to do it. Render different layers use different setting.
Tony Su
Product Support
morinnicolas8944
That's what afraid of. It's not really something that can be done on the plugin side then.
Thank you for the information.
