Error loading Renderman 22 in Maya 2018.3
Hi, I have this problem where Maya 2018.3 does't load Renderman 22 even if all is installed well.
I put the error that Maya shows:
# [rfm] INFO: <module>: Loading RenderMan for Maya -----------------------------------
# [rfm] INFO: setup_environment: 22.3 @ 1929077 - windows10_x86-64_vc14icc170_external_release built on Wed 09 Jan 2019 @ 11:17:01
# [rfm] INFO: set_rmantree: RMANTREE = 'C:\\Program Files\\Pixar\\RenderManProServer-22.3'
# [rfm] INFO: check_maya_module_file: Using module file: C:\Program Files\Common Files\Autodesk Shared\Modules\maya\RenderMan_for_Maya_22.3.mod
// Error: file: C:/Program Files/Autodesk/Maya2018/scripts/others/pluginWin.mel line 290: WindowsError: file C:\Program Files\Autodesk\Maya2018\bin\python27.zip\os.py line 157: 2 //
// Warning: file: C:/Program Files/Autodesk/Maya2018/scripts/others/pluginWin.mel line 290: Failed to run file: C:/Program Files/Pixar/RenderManForMaya-22.3/plug-ins/RenderMan_for_Maya.py //
// Error: file: C:/Program Files/Autodesk/Maya2018/scripts/others/pluginWin.mel line 290: (RenderMan_for_Maya) //
Hope anyone can help me. I already ask in Renderman's forum but it take long time to respond.
I have the same problem as you since yesterday, if you solve your problem with that can you tell me please? I' m begging you.
