Announcements
Display typed expressions in Expression Editor when selecting expression nodes?
dkrelina
dkrelina
I've written a simple expression to control the frameExtension attribute of a file node. Once I've made the expression and I want to edit it, how do I re-display the typed expression inside the Expression Editor?
When I select the given expression node, nothing shows up in the expression text box.
The only way I've been able to view the expression has been to select the node with the affected attribute, then dig through the list to find the relevant one.
Is there a faster way to display typed expressions within an expression node?
rajasekaransurjen
Try this....
In the expression editor menu...
Select Filter > By Expressions Name.
here you can see the expressions by name(in the below image it is expression1)
dkrelina
Thanks @rajasekaransurjen! The filter makes it a lot easier 😀
