Announcements
Announcements
We are currently migrating data within this board to improve the community. During this process, posting, replying, editing and other features are temporarily disabled. We sincerely apologize for any inconvenience caused and appreciate your understanding. Thank you for your patience and support.
Deformer Sets Become Uneditable an appear empty
jmreinhart
Advisor Advisor
Message 1 of 1
jmreinhart
So I have two deformers in parallel like in the image below. When they evaluate they behave with the deformerSet is still set up. But when I try to edit the deformer set of cluster 2 or 3, they show up and being empty. They're empty when using the edit deformerSet tools, the getAttr command, the MFnSet, and when testing in the node editor.
I have found some workarounds for editing the deformerSet but they all require rewiring the input/outputGeometry which isn't a very good solution, especially for non-technical users. I reported it as a bug to Autodesk but I wanted to see if anyone else had dealt with this problem before.
I'm working in 2020.3 but I tested in 2018 and it happens there as well
Replies (0)
