Custom command line UI, I only wants the warning part of it
Hey all!
I am creating a custom UI  for a tool and I'd like to have only the error/warning part of the commandline to appear. Do you have any idea how this could be achieved? See attached image
I couldn't find any interesting ideas using script jobs. Any idea?
Thanks for your help!
rajasekaransurjen
Can you share your script.
Hi!
I am trying to find a solution using maya's online commandLine documentation. Here is the code
I thought about having a form with a negative offset, it worked if I had a static window, but I'd like to have it stretching.
import maya.cmds as cmds
window = cmds.window()
form = cmds.formLayout()
cmdLine = cmds.commandLine()
cmds.commandLine( cmdLine, edit=True, height=25)
cmds.formLayout( form, edit=True, attachForm=[(cmdLine, 'top', 0), (cmdLine, 'left', 0), (cmdLine, 'right', 0)], attachNone=(cmdLine, 'bottom'))
cmds.showWindow( window )
Thanks 🙂
