I am trying to create a python script to swtich an image plane between cameras.
The scripts works fine but when I add animation keys to the cameras I get this error:
Error: RuntimeError: file <maya console> line 23: Unable to edit the image plane.
This is my script:
#Compose shot import maya.cmds as cmds import maya.mel as mel #Get camera shot clip atrributes camSel = cmds.ls( sl=True ) print camSel if len(camSel) == 1: camSelShape = cmds.listRelatives(camSel) print str(camSelShape) clp = cmds.listConnections( camSelShape, d=True ) matchingClip = [s for s in clp if "clip" in s] #Get attribs from clip getAst = cmds.getAttr(str(matchingClip[0]) + '.startFrame') getAet = cmds.getAttr(str(matchingClip[0]) + '.endFrame') #Set up the Maya GUI to compose the shot cmds.playbackOptions( ast = getAst , aet = getAet, min = getAst , max = getAet ) cmds.lookThru( 'perspView', camSelShape[0]) cmds.currentTime(getAst) #Connect IP to camera print cmds.listRelatives(camSelShape) cmds.imagePlane( 'myIp1', e = True, d = True) ipcamera = cmds.imagePlane( 'myIp1', camera = str(camSel[0]), e = True) mel.eval ( ' showEditorExact(' + camSelShape[0] + '->myIpShape1) ' ) else: print "Select only one camera"
Any help will be appreciated.
Solved!
If the imagePlane has some imput connections such as the size it is not possible to edit the imagePlane in python.
