Combining multiple rigs
Hey,
I need a little help if possible,
Currently have 4 pieces to my model (head, arms, torso, legs)
Trying to combine them all together onto one rig and then copy the weights over
A lot of the joints in one rig are in another, so there's multiple occurrences of each.
I've tried to make it as simple as possible but it's quite complex, I'm not absolutely terrible at scripting but can't figure this one out so thought I'd turn here for help.
I need to make a script as I'd like to be able to do these characters in batches and make it as quick as possible. Combining the rigs together was the easy part. Just having trouble with the weights
They all get copied over but a couple of them end up really screwed.
Any help is highly appreciated 🙂
Thank you
Here's the script:
    #Lock all weights so new joints being added to skinClusters don't effect current weights
    for joint in cmds.ls(type="joint"):
        if cmds.objExists(joint+".lockInfluenceWeights"):
            cmds.setAttr(joint+".lockInfluenceWeights", 1)
    #Move new joints to skinClusters
            for skinCluster in cmds.ls(type="skinCluster"):
                if("COMBINED" not in joint and joint in cmds.skinCluster(skinCluster, query=True, influence=True)):
                    if("|" in joint):
                        cmds.skinCluster(skinCluster, edit=True, addInfluence="COMBINED:"+joint.split("|")[-1])
                    else:
                        cmds.skinCluster(skinCluster, edit=True, addInfluence="COMBINED:"+joint)
    #Unlock all weights
            cmds.setAttr(joint+".lockInfluenceWeights", 0)
    #Transfer weights from old rigs to new rig
                if("|" in joint):
                    cmds.skinCluster(skinCluster, edit=True, selectInfluenceVerts=joint)
                    cmds.skinPercent(skinCluster, transformMoveWeights=[joint, "COMBINED:"+joint.split("|")[-1]])
                    cmds.select(deselect=True)
                else:
                    cmds.skinPercent(skinCluster, transformMoveWeights=[joint, "COMBINED:"+joint])
mcw0
Firstly, to add new joints as influences, you don't have to lock all the other joints first.  You can just add the new joints with the lockWeights flag set to on.
As for transferring weights, you say "They all get copied over but a couple of them end up really screwed.".  I personally don't use the "transformMoveWeights" option much as I find it slow.  You can lock all influences except the 2 in question.  Then you can query the weight of the first influence and apply that as the weight for the second influence.  This should not result in any "screw ups".  🙂
That sounds exactly like what I was looking for, and I didn't see that flag. Thanks!
You say "Then you can query the weight of the first influence and apply that as the weight for the second influence."
Do you have an example snippet of this? Not sure which command you're talking about
Also, thanks for the response.. appreciate it 🙂
mcw0
float $weight = `skinPercent -t $influence1 -q -v $skinCluster1 $pt1`;    //  This will query the weight of $influence1 on $pt1
To apply the weight:
skinPercent -tv $influence2 $weight $skinCluster2 $pt2;
