can't import GS curve tool
30008163
30008163
I'mCapture2.JPG trying to import gs curve tool to maya 2023, i've downloaded the new version but i keep getting these errors in the script editor when i import it , can anyone help me ?
Kahylan
Hi!
You are trying to run a Python command from a MEL Tab, that's what is causing your issue. Just copy the code, click on the little tab above the code that sayis "Python" on it, insert the code there and run it. If the plugin is in the right folder it should start up.
I hope it helps!
thank you ! didn't realise I didn't click on the python tab !
