apiMeshShape example plugin doesn't show up in UV Editor
I have been able to compile and load the apiMeshShape example plugin in Maya 2017, and it shows up correctly in both the Legacy Viewport and Viewport 2.0. However, I noticed that it doesn't display any of its UVs in the UV Editor. This example plugin implements both the canDrawUV() and drawUV() methods, and as far as I can tell from the documentation these are the only things necessary for display in the UV Editor:
http://help.autodesk.com/view/MAYAUL/2017/ENU/?guid=__files_GUID_B8944200_F3A7_479F_BD54_990DF95EAD3...
Does anyone know how to fix this, or is support for the UV Editor in custom MPxSurfaceShape nodes simply broken in Maya 2017?
Replies (0)
