Hi
I am using the apply_render_setup module to assign render settings information in my scene from an external json file. However, there are some attributes I do not want to change - for example, I have created some layer overrides that also get affected when I apply the settings that I wish to remain unchanged.
Ideally I would like to either be able to check what attributes have overrides and ignore them, or alternatively simply be able to lock those attributes to ensure they are unaffected. When I try to lock them, the apply module give an unexpected internal failure error, presumably because it cannot access the attribute.
Would anyone have any recommendations as to how I might achieve this?
Craig
