Accessing color/transparency attributes on a shader and export as image texture.
zachcoley123
zachcoley123
I am trying to build a plugin which iterates over each shader in a scene and for each ".color/.ambientColor/.transparency" attribute (just to name a few common attributes) on a shader it generates and exports a image file texture which condenses all the complex shader network graph infomation into a single image, for example a procedural maya ramp node exported to a single image called "ShaderName_base_color.tiff".
I've tried to build something like this before in PyMEL, however when I accessed the shaders color attribute it would always say float3 (0.0, 0.0, 0.0) even if I had a file texture node connected, I couldn't just access the individual pixel values so that I could then feed those through a image exporter to export a image?
I'm now trying to do this but this time in C++ using the Maya API but I'm not sure how to correctly get a reference to the attribute value for a color attribute or MPlug.
Is getting a reference to the shaders color attribute the place to start? or is there important something I'm missing?
I feel that i need to access the data a certain way in order to obtain individual pixel values and iterate over pixel coordinates.
Since I'm new to the C++ API (I have some knowledge of C++) I started my plugin using a example by Autodesk called "nodeInfoCmd/nodeInfoCmd.cpp" which simply creates a custom command which will output information on all nodes in the current selection list and I've started to modify this code to output the attribute/plug type and the value e.g float3.
But I'm not sure what type to use to get a reference should I use plug.asMObject or MObjectHandle or .asFloat or .asDouble? I have no idea.
I can post the current code I have if needed?
Any help would be greatly appreciated.
Thank you.
Zach Coley.
jmreinhart
There is a feature in Maya that bakes complex shader networks into images.
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Maya-Lig...
I'm not sure how it handles transparency though.
zachcoley123
I have heard about a feature in Maya which does this and I did consider using it, however I would like my plugin to have the ability to convert a shader automatically, e.g from a maya blinn to Arnold AiStandardSurface for example, where the plugin as mentioned first creates and exports baked textures and then automatically applies those textures to a new different type of shader.
Regarding transparency I figured exporting an image as a black and white alpha texture should work fine as transparency usually uses an alpha texture map as input.
I just need to figure out how I can access the RGA pixel values of a single pixel in a nodes colour attribute instead of just a float RGB value for the entire colour attribute.
Thank you for the suggestion.
Zach.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
