A hotkey for fine / slow movements when modeling?
joeltilling
Observer
Observer
joeltilling
Observer
Observer
II have had maya for a while at home however i have never truely played around with it until now, but it is jumpy when moving things, so rather than a gradual move where i like it has set places in which it jumps to locked locations not only that my test rending isn't working when i have both my monitors connected however when i disconnect one the render appears. Is this a settings issue or a pc issue or something?
I believe the movement issue is due to my ram because at my college we dont have this issue however the test rendering shouldn't be the case, is it in settings or something.
Hi
CTRL + Click -drag inside a value-field.
for monitor if you are using win 10
Use the following instructions to either extend or duplicate the desktop with a second monitor:
  1. Right-click anywhere on the desktop.
  2. Click Display Settings.
  3. select duplicate these screen
