Xgen Python disable a Modifier
landonjpginn
landonjpginn
I have been looking throught the API and all the source code and I cannot find any way to disable a listed Modifier for my XGen description.
If i use xg.fxModule( palette, description) it lists the one i want to disable ("BakedGroomManager")
But how do I access the ability to set its state to Active?
xg.setActive(palette, description, 'BakedGroomManager', False)  Does not work.
and while I can run
xge.removeFXModule(palette, description, 'BakedGroomManager')
I do not want to delete the fxModule. Only set it to inactive.
Any help will be greatly appreciated.
cheng_xi_li
Autodesk Support
Autodesk Support
I think you could refer to activeClicked function at xgui/tabs/xgFXStackTab.py
isChecked = ( item.checkState() == QtCore.Qt.Checked )
xgg.DescriptionEditor.setAttrCmd( str(item.text()), "active", xg.boolToString( isChecked ) )
xgg.DescriptionEditor.playblast()
xgg.DescriptionEditor.fxStackTab.getCurrentStackUIWidget().activeUpdate()
It should be the way how xgen active/deactives its module.
Yours,
Li
How do I hit those buttons with Python? Disabling preview is no good to me if I can only do it in the UI.
awu2500
xg.setAttr('active', str(0), palette, description, modifier)
